High Palcebo peaks in sample chromatogram
Hi all,
It has been quite long since my last post!!. I have a question,
In our drug product related substance chromatogram there are some peaks observed sample as well as in placebo. However, the peak response is higher in the sample (40 to 50% higher). Should we have to report it? Anybody faced such issues?. How to go ahead about that?
Appreciate valid responses,
Vijayak
That strongly implies that your sample contains peaks that co-elute with peaks from the placebo. I'm sorry to be the bearer of bad news, but at a minimum, that "excess" area should be reported. If it represents a sufficient area to be identified, I would recommend that you develop an orthogonal method to separate what is sample-related from the placebo.
Users browsing this forum: Bing [Bot] and 15 guests
