Salt concentration
I need to do some small scale ageing under controlled humidity. I will be using humidity cabinets.
Does anyone know what salt and at what concentration I need for 65% RH
John
The following link is in German but you probably can identify most salts on the list very easily. at 20°C a saturated ammonium nitrate solution should give 65% rel. humidity.
http://www.d-r-h.de/hilfstabellen/klima ... uchte.html
and here is one from Omega (does not have the ammonium nitrtae data):
http://www.omega.com/temperature/Z/pdf/z103.pdf
I have another table from an old Merck KG catalogue which I have to find first.
cheers,
Robert Haefele
Robert
Thanks very much .
That is very useful info
Regards
John
John
If you will search in Google.com you will get one control humidity chart pdf.
