Waters X-Bridge Column : Maximum water proportion ?
Hello all,
I try to separate some compounds on a X-Bridge.
With a proportion 90/10 Water/Acetonitrile, i have some resolution but not enough.
Someone know if this column can tolerate a proportion of 95% water ?
Thanks for your help
Laurent
Laurent Collard
UCB Pharma
Dear Icollard
i hope your answer is available on this side
http://www.waters.com/WatersDivision
Some time resolution is depend on column temperature, pH of buffer
you can try
You definitely can go to a higher water content. 95% is not a problem.
