Problems with HGL files
Dear Friends,
I have some "old" graphic HGL files that I can no longer display on my computer. Does anyone know of a way to convert this type of files to somethinmg more common such as BMP or JPG, or something else?. I would appreciate any help.
Thanks for your help
josebenjamin
I use Paint Shop Pro (JASC software) routinely. It works with hgl files, and can save to a wide range of other file types. It used to be a shareware program, but has recently moved "up-market" to compete with Photoshop. If you do a Google on "Paint Shop Pro" and "shareware" you should be able to find at least a free trial copy of one of the older versions.
Thanks very much for the tip about Paint Shop Pro. I have also learned that Windows 95 has a filter that allows the HGL file transfer into Powerpoint presentations. Unfortunately the filter is not present in later Windows versions.
josebenjamin
In total there are 9 users online :: 3 registered, 0 hidden and 6 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 6 guests
