Microbore HPLC
I am in the learning phase of ‘Separations’. I am trying to determine organoarsenic and their transformation products using LCMS. I have difficulty in the HPLC part of this experiment. I tried anion-, cation-, and combination of both exchange columns using various mobile phases (read from literature), but remain unsuccessful. I come across this article using Microbore HPLC with a C-18 column. Our facility does not have a Microbore HPLC (neither a Microbore column nor a suitable HPLC setup). My question is can I use a regular C-18 column on a regular HPLC setup to try their interesting protocol.
gradstudent
Yes you can, the results will be almost identical (in terms of chromatographic resolution, assuming same particle sizes etc)...
Users browsing this forum: Google [Bot] and 8 guests
