octadecylsilyl vinyl polymer column
Hello HPLC expert,
Can someone recommend me any HPLC column with octadecylsilyl vinyl polymer packing material? it is used for perfloxacin impurities B and C.
Louise :wink:
I read this column type as a bit of a contradiction, have you got a more complete reference for the application - pharmacopoeial, perhaps? The only mixed column I've personally heard of are the CapCell Pak line, however these employ silicone-polymer-coated silica particles. If you want a fully polymeric column that's much easier, but I doubt you'll find one with C18 stuck to it.
This could also mean some type of polymer-based C18 column. Look for ODPerfect from Shodex.
Users browsing this forum: DuckDuckGo [Bot] and 2 guests
