Void volume marker for SAX phase
What are the most common void volume markers for anion exchange columns? The compound should be UV/Vis detectable.
Hi Martin,
Anny UV absorbing, neutral compound should do the trick. Acetone might be a good choice.
If your AX column is resin-based, you may find that solvents dissolve into it, so it may be preferable to use a slightly higher MW neutral compound.
Bruce Hamilton
