Purity of anhydride by HPLC
I try do determinate purity of an anhydide by hplc without using derivatization.
Thanks.
Since anhydrides react with water, alcohols, amines, etc. you should think about normal-phase chromatography. Even then, many common stationary phases adsorb water or have alcohol functional groups.
Are you sure you don't want to derivatize?
Mark Tracy
Senior Chemist
Dionex Corp.
May be Normal Phase HPLC, using aprotic solvents (MtBE/Hexane) and water-control procedures for stationary phase?
(search the forum for analysis of water sensitive materials)
In total there are 19 users online :: 2 registered, 0 hidden and 17 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 17 guests
