AUC(PK) Standard deviation
I hope this fits in with the rules of this forum. (The data is acquired by HPLC at least)
We have been analysing murine plasma for concentrations of a drug. We have 3 points per timepoint and each mouse can only supply one data point.
We can easily calcualte mean AUC by averaging each point then calculating by either trapezoidal or WNL analysis. However we are required to add a standard deviation to the AUC.
Would using the mean +SD at each concentration then calculating AUC give the upper value? (and vice versa for low) Seems a bit of a fiddle?
Any help on this would be great (or a link to a more suitable forum/website).
Thanks!
James
Try this forum and ask your question:
http://www.boomer.org/pkin/
kind regards Bert
thanks, appreciated.
James
What's the reason to add a stdev to the mean?
Is it to calculate the confidence intervals, or to find %RSD?
I'm not sure what you are trying to do, please clarify.
Also, if you got an answer, please do post it.
In total there are 19 users online :: 2 registered, 0 hidden and 17 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 17 guests
