In soluble product - Residual solvents
9 posts Page 1 of 1
Hai,
There is a problem for analysis of residual solvents of my drug substance Buclizine .
This substance is not soluble in any solvent. It is sparingly soluble in propaediol, ethanol.
To analyze residual solvents for this product how can I perform sample preparation .
It was not soluble in any solvents like DMF, DMSO, NMP and other organic solvents.
At what temperature does the product melt?
best wishes,
Is
Buclizine , or 1-(p-tert-Butylbenzyl)-4-(p-phenylbenzyl)piperazine dihydrochloride
soluble in water?
soluble in water at 80°C ?
Do you know at what levels it is soluble at these conditions?
best wishes,
another suggestion is to try to dissolve Buclizine in water: DMAc, 1:1, and heat it to 80°C 10mg per 100 µL or 500 µL
If you have to use a concentration of less than 0.1mg/mL you could always use SPME headspace.
best wishes,
Rodney George
Senior Research and Development Scientist
Gas Separations Research
Supelco
595 North Harrison Road
Bellefonte, PA 16823
814-359-5737 voice
814-359-5459 fax
rodney.george@sial.com
Is the analysis by headspace. If so, waybe benzyl alcohol. I had a similar situation with a compound that was slightly soluble in ethanol. I went with benzyl alcohol and it went into solution after heating to 80°C.
Chuck
It is not soluble in water at any temperature
thank you for your suggestion ROD
Let me know the melting temperature.
If it is reasonable <120°C you could do headspace analysis just by melting a 1-10mg sample in a vial.
best wishes,
Rodney George
Supelco
814-359-5737 voice
814-359-5459 fax
With the appropriate precautions and very long equilibrium times you might be able to do the analysis by equilibrium headspace over a powdered sample.
Thank you peter for your valuable suggestion
I will come back after conducting the experiments.
rama krishna
9 posts Page 1 of 1
Users browsing this forum: Semrush [Bot] and 6 guests
