Solution Stability
Hello everyone!!
I'm working on a molecule which is stable in basic medium, so when i perform the dissolution, i stabilize it by adding a little quantity of base i.e NaOH, recently when i stabilized it with KOH the sample degraded in less than an hour....my question is if my molecu;e is stable on the basic side, then why did it degrade....KOH is more basic than NaOH right!!!!
Morningstar
I think you would be better off adding a known quantity of a buffer which would adjust the solution to a consistent pH.
Do you know the stability of the product as afunction of pH
Users browsing this forum: Google [Bot] and 2 guests
