chemstation software, creating dropdown menus
Can you create dropdown menus for frequently used samples names in the sample info. section or sequence table? I maintain gc's at various sites. The instrumnets are used by multiple production operators with little or no experience with GCs. It is imperative that I create a list of sample names that cannot be changed, to be able to manage the data. Please help.
What version of chemstation are they operating, as the later versions of G1701 and G2070 can import sequences from a file.
Alex
I have G2070. The problem is that they do not run the same sequence or order every time. Dropdown menus would be best.
I've seen different things by googling about making the section a hotspot by using visual basic butr that is beyond me at this point. I may have to dig deeper.I had hoped one of you compertur gurus could help.
