From Packed to Capillary
I am trying to peform the related substances of Tranylcypromine Sulphate. The BP method says to use the following column:
- Glass column (1.5 m × 4 mm) packed with acid-washed, silanised diatomaceous support (100 to 120 mesh) coated with 3% w/w of cyanopropylmethylphenyl methyl silicone fluid (OV-225 is suitable).
Does anyone know of any capillary columns that could be used as an alternative or which suppliers in the UK still offer a wide range of packed columns.
Any of the column manufacturers will be able to tell you which of their columns is the best match. Check out their web sites.
In total there are 16 users online :: 2 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 14 guests
