Loss of resolution in GC-MS
Posted: Wed Sep 08, 2004 12:35 pm
Help!!! I am running PAH analysis on GC-MS, and I have 2 problems that I can't solve. First, I am losing resolution towards the end of each run and cannot firgure out what is causing this. Second, there is a loss of response for the internal standard in each sample. In the calibration standards, 20ug/ml internal std. gives a response of 9000, but the same concentration in the actual samples gives only half that. Is this some sort of matrix effect?
