PDA detector
Any one who is using LC-8A Shimadzu HPLC, could help me in sorting out the following problem.
Failed to intilization PDA detector.
I have checked all hardware, software problems, but no solution.
Regards
What is the detector model and the software system? LC-8A is a pump.
Wanda
Don't turn on your detector manually, let the software interface do it for you. I've found that this helps to eliminate "error messages". I know it may sound counter-intuitive but this helps to solve problems.
Jumpshooter
Users browsing this forum: Bing [Bot], Semrush [Bot] and 7 guests
