The standard is used nearly every day so we keep having to remove it from the fridge use it and put it back, is this likely to increase the risk of moisture intake? Unfortunately we did not have the forsight to perorm a moisture conetnt analysis at the point of initial quantification.
Anyone else seen anything similar to this or have any comments?
