Appropriate concentrations for DB-5ms columns?!
is somebody working with a DB-5ms column (30m, 0.25mm, 0.5um) and has a tip for a appropiate concentration for the samples? Im analysing aromatic compounds (cresol/xylenol/phenol) with toluene as solvent.
Thanks!
Oliver
100 mg per liter should be no problem.
Depends on your injection parameters - injection size and split ratio. Capacity for this dimension column is approx 200-250ng
I`m injecting 1 ul and using the spitless mode.
Oh my, then 100mg/liter is much too concentrated.
Less than 0.1mg per liter is a better working concentration.
best wishes,
Users browsing this forum: Ahrefs [Bot] and 20 guests
