DAD Lamp
hi everyone,
I fixed the new deutrium lamp , and after that in my blank run i get a lots of peaks more than 100..Can you please let me know how can i avoid these peaks.I warmed up the lamp for more than 4 hrs.
I can send the peak if you could send me ur email.
Thanks.[/img]
Did you wear gloves and avoid touching the lamp itself? I'll assume your system uses an alignment pin so no lamp alignment is necessary. Leave it on overnight, report back tomorrow as better, same, or worse.
Users browsing this forum: Bing [Bot] and 11 guests
