viscosity and mass transfer
is it true that the higher the viscosity of the mobile phase, the lower the mass transfer
thanks
Liv
Yes, and the lower the plate counts.
Yes, and the broader the peaks and the poorer the resolution. The van Deemter optimum shifts to a lower linear velocity of the eluent, therefore the separation should be run at a lower flow rate.
Users browsing this forum: Bing [Bot] and 13 guests
