7697A on Empower 3 - Instrument Failure
Hi ,
Anybody came across this problem ?
Using the same instrument method ::
I set up a sample set using wizard and calibrate at the beginning (bracketing stds)
The headspace picks up vial, moves to oven then instrument failure occurs and HS vial
I removed the calibrate function from the sample set and it carried out vial preparation as normal and acquired data once injected
Any thoughts why it should fail with calibrate/quantitate commands ?
Hi
Anybody any thoughts on this
Carried out a sample set no problem without functions
when functions added as per sample set wizard 7697A errors with instrument failure
So adding functions after sampel set ran only option?
In total there are 28 users online :: 2 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 26 guests
