Conversion factor
I have free base as standard and hydrochloride salt as my sample...How I should calculate my % recovery..what will be the conversion factors..how to calculate that..thanks in advance
factor =MW of salt/Mw of free base, this will produce a factor >1
Multiply your results by this factor to obtain the salt concentration from the measured free base concentration.
or (preferably)
Convert you STD concs to equivalent salt concs (factor =MW of free base/Mw of salt, this will produce a factor <1), by multiplying the free base conc by the factor.
Tip: if you do the adjustment at the Stock STD prep, you only need to do one calculation (calculate all other STD concs as normal from the "adjusted" Stock STD conc)
Users browsing this forum: Google [Bot] and 12 guests
