API 3200
Dear colleagues.
In a LC MSMS API 3200 with software analyst is possible to read ESI positive and ESI negative simultaneously ?
You can switch polarities during your run. All you have to do is change your acquisition method. The instructions are in the Analyst manual:
http://www.2shared.com/file/9167373/b3b ... anual.html
All you do is add a period.. Start on page 133 and go from there!!
Have fun and good luck!
Kerri
Thanks Kerry
