thiourea preparation for HPLC
when performing Biopartitioning Micellar Chromatography which is a branch of Micellar Liquid Chromatography , retention factor is extremely needed.
I need to calculate dead time T zero using thiourea as unretained compound by the column , and then, find retention factor value for my sample.
Please, indicate me how to prepare thiourea for measuring actual void volume of a specific HPLC column ?
Serge
The same way you would prepare your actual samples.
@Tom do you mean with the same concentration ?
Users browsing this forum: Bing [Bot] and 1 guest
