When I process a run using the "Acquisition Method Set" its fine and I get a complete result set but when I pick "Selected Method Set" I often get only half the run processed with errors in the Message centre saying there isn't enough memory to complete processing.
Could it be that when I pick a certain method set that has processing methods that have been updated since acquisition the extra memory is too large? Because it doesn't happen with the acquisition method set.
