printing report (agilent 1200 chemstaion)
hello everybody,
can somebody tell me how to print many overlaid chromatograms; I can do it separately (one chromatogram with results), but I cannot do couple of them in one report (I had information: your chromatograms are overlaid, to print the report use load signal option, but if I use load signal option there is only one chromatogram not more)
another question, is it possible, when I do manual integration to more decimal places than one; of course, when I print chromatogram there are 5 decimal places, but on the screen, when I integrate manually, there is only one
is it possible to change something in the report pattern to do it?
thanks
First use File, Load Signal to load the first chromatogram, then use File, Overlay Signal to overlay the second. Then integrate and print report.
And you must be in View, Full Menu to get the option of overlaying chromatograms.
You cannot generate a report when you have multiple signals loaded from separate files. If the multiple signals are from the same data file, and are selected in Signal Details, then the report will print.
If you want to print a window with overlaid chroms, choose File, Print, Print Selected Window.
Merlin K. L. Bicking, Ph.D.
ACCTA, Inc.
You also have to go under Signal Options and set to Overlaid with All in the Same Scale or Each in Full Scale, depending on what you want to show.
Users browsing this forum: Bing [Bot] and 21 guests
