Empower custom calculated field
New to the forum, I need help on creating a custom calculated field in empower. Any help will be appreciated
I like to create a custom field in empower that will calculate the % Difference (%D) in the average response factor (RF) of a reference peak for two standards following this equation
%D = [Average RF (Std1) - Average RF (Std2)] / Average RF (Std1) x 100
The sample set is as followed
3 injections of Std1 followed by 2 injections of std2.
TTran
Maybe you should give us some more information about what kind of software you are using?
Ace
I am using Waters Empower v. 1 build 1534
TTran
Ace
:oops: Posted in the wrong thread...
Maybe I'm wrong, but this sounds like intersample calculations, and I'm not sure that this was possible with Empower 1.
If so, take a look at the help pages for intersample calculations, you should label your references and use this labels to get the custom fields to work.
GL
Ace
Thank you for replying.
My sample set is as follow:
Code: Select all
Sample Name         Injection   Label
Std1                 1             A
Std1                 2             A
Std1                 3             A
Std2                 1             B
Std2                 2             B
I created result custom fields with the following equations.
ARF_A = A..(AVE(RF))
ARF_B = B..(AVE(RF))
use the above equation, instead of calculating the Average RF, Empowers listed all 3 RF values for RF label A and 2 RF values for RF label B
Did I do something wrong?
Thank you all, I figured it out. Forgot to add a summary calculation in sample set
Users browsing this forum: Google [Bot] and 2 guests
