"MS communication : Disabled"
Hi, after a shutdown of the MS (power cut) I see on the statut of the GC MS agilent 7890B "MS communication : Disabled", I want to know if i can reconnect the MS communication. But I don't remember if before the power cut the statut was "MS communication : connected", I think yes. Is it a problem to continue with this message in the statut ?
Thank you,
Jérémie.
Thank you,
Jérémie.
Try loading the control software and see if the message goes away. My 7000 triple quad displays that message all the time but it still talks to the software.
Hey this is benign and you're better off leaving it disconnected.
You can connect the GC and MS via LVDS cable and then configure communication from the front panel of the GC using the aux detector or ms detector button on the GC. It doesn't add many features, leaving it off is fine.
In total there are 24 users online :: 2 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 22 guests
