Atp, 1 drug, 3 peaks
Hi everybody! :)
I´m almost sure but, however i would like your opinion...
I´m analyzing Atp and i´m having 3 peaks, and i suppose those peaks are AMP, ADP, and ATP.
I´m diluting Atp with water.
Probably ATP is losing 1 and 2 phosphates because its reactivity isn´it?
Thanks in advance!
I believe you are right. Run the sample using both a highly aqueous compatible RP column and an anion-exchange column, and you will observe different elution order (or selectivity).
Xiaodong Liu
you can purchase ATP, ADP, and AMP materials from Sigma and easily confirm the elution times
Users browsing this forum: Semrush [Bot] and 17 guests
