agilent Masshunter qualitative Formula calculator
Hi
Does anyone use the Mass calculator and Formula calculator options of MassHunter to identify compounds using the mass spectrum?
Thanks ydna1977
I did try the familiarization guide before posting this question. I need to know if anyone uses the mass calculator and formula calculator.
I need to know how to proceed if my GCxGC chromatogram has a compound which I cant identify using NIST as my 1st column is wax ( which is not always easy to find matches for).
hi ,,
sorry :)
ok try this as reference
https://www.agilent.com/cs/library/slid ... Tricks.pdf
Hi ydna1977
I found what I was looking for in the second document you sent. Wonderful! Y
our help is much appreciated?
Cheers
In total there are 29 users online :: 1 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 28 guests
