chromeleon software problems
Hi there, wondering if anyone can help. I am currently running ion chromatography (dionex) using chromeleon software.
There appears to be a glitch in the software and the instrument stops after one injection in the sequence. Has anyone encountered this before.
Any thoughts?
Scio
scio2
Difficult without detailed information on the communication protocols between the instrument and the software. A setting or a minor communication problem might be causing this. Best will be to contact your local Dionex support and to provide them with a system status report (SSR). This report includes all required information and is created automatically (but can be customized) and will make a proper diagnose of the problem easy. SSR is included in CM 6.8, older versions such as CM 6.7, 6.6, and 6.5 can be upgraded. Please click here for details: http://www1.dionex.com/en-us/lp39254.html
I can help you if you send me backup of Audit trail file of that day and one backup of your sequence sample.
To large data please send trouhg www.yousendit.com
AR
In total there are 12 users online :: 3 registered, 0 hidden and 9 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], John Guajardo, Semrush [Bot] and 9 guests
