acetic acid and peroxyacetic acid
Does anyone forsee me having any problems analyzing peroxyacetic acid (pKa = 8.2) along with acetic acid on a C18 column with acidic phosphate eluent?
Randy
Dig for gold on the Moon...
Why don't you consider IC, HILIC or even ion-pairing techniques?
However, at an (at least slightly) acidic pH and with a sensitive detector a C18 column may do. The questions is if you get sufficient selectivity?
I bet there are Application Notes available from other suppliers. ZIC®-HILIC has proved to be useful for carboxylic acids, see http://www.sequant.com/sn/ufiles/SeQuan ... 00-13A.pdf
Merck SeQuant AB
Merck SeQuant AB
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
