Purity in Certificate of Analysis
Someone can explane to me the difference between " Chemical Purity" ; "Chirlal Purity" ; "Optical Purity" ; "Potency Assigned"?
Which is the best parameters to use for calculate the assay?
Many thanks
p
Suggest you contact the producer of the C of A for clarification
Potency values generally account for both water content and inpurity content of the material. I would use this value in STD calculations
The others are probably impurity factors determined by a series of proprietary measurement techniques.
Good judgment comes from bad experience, and a lot of that comes from bad judgment.
In total there are 40 users online :: 1 registered, 0 hidden and 39 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 39 guests
