limits on 100 % recovery active
Hi, the limits for the check standard in pharmaceutical analysis at 100 % recovery is typically 98-102 %. Does anyone have a reference for where this figure comes from
Scio
scio2
Hi Scio
I think these limits are based on the accuracy of the method. If your method accuracy has a limit of 98 - 102% then your std recovery would also be the same. We generally use a recovery value of 98 - 102 % for the API and 10% for degradation/impurities.
In total there are 14 users online :: 5 registered, 0 hidden and 9 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot], John Guajardo, Semrush [Bot] and 9 guests
