Is changing column robustness test or ruggedness test?
Posted: Thu May 22, 2008 7:47 pm
what is the difference between robustness and ruggedness?
thanks a lot!
thanks a lot!
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
If we want to use the procedure in routine analysis and we have certain column supplier it is not necessary to use column from different supplier or different column type from the same supplier in the ruggedness/robustness test unless we want to search alternate column. We could use different lot or age.Note that simply changing to a different column is not enough. You must use a column from another supplier or of a different lot.
