Empower - Standard Purity Query
Hi ,
Standard purity 100.4 % standard component only 0.0- 100.00 allowed in Empower
any thoughts ?
Ignore the purity tab and take it into account when calculating your value in the component editor or make a custom field and multiply your amount by purity of component set in CConst1.
Cheers
factored in as part of standard weight
Custom fields an option though validating a nightmare ?
How do you go about this ?.. test scripts .. sops ?
Do you have SOPs in your company about validating custom fields. Usually you test the formula (eg Amount/100*CConst2) in a separate project on 2 or 3 peaks and compare the value you get with a calculator with that of Empower to ensure they are the same.
Users browsing this forum: DuckDuckGo [Bot] and 9 guests
