pre column filter or guard column
I would like to know if I can use a precolumn filter whithout a guard column?
thank you
yes
Yes you can, but a precolumn filter gives you less protection than a guard column. If indeed the problem is only particulate debris, then both work equally well. If the problem is something else, guard columns provide a better protection.
I've heard so much about guard column, in what circumstances do we use a guard column? And what is a guard column?
http://www.restek.com/aoi_general_A015.asp
Especially useful if the sample matrix is not particularly "clean".
