Custom fields beginner
At work we have started to use custom field and I'm trying to understand the most basic concepts. My question is, for the field type "component", when and why is useful?
I know that if I create a custom field type "component", I can see it in amount, but I don't understand for what it can be used.
Thank you so much in advance.
Hi ,
Back in the day component field were only used for purity level /amount
After Empower 3RF2 not needed
Use component Cf for acceptance criteria as Cconst in processing method, for example
Remember these require validating
Users browsing this forum: Bing [Bot] and 1 guest
