Chiral separation
I need help. Does anybody have some experience with chiral separation of N-acetylserine or 3-aminopropane-1,2-diol in HPLC??
Both molecules are quite small and it´s problem with detection, because 3-aminopropane-1,2-diol doesn´t have any chromophore and N-acetylserine has only two carboxy groups.
I tried pre-column derivatization of 3-aminopropane-1,2-diol with OPA reagent. Problem with detection was solved, but separation didn´t pass.
Then I tried post-column derivatization and for separation used Crownpak column, which is for separation of amino groups, but racemic mixture wasn´t separated.
I´ve tried it separate also on capillary electrophoresis after derivatization with dansyl chloride, but separation wasn´t good.
I will be very glad for every advice.
Thanx
This should be pretty straightforward. Just OPA derivatize both and you should be able to separate the diastereomers formed using a good reversed phase HPLC column. Try it.
How does OPA form diastereomers?
Derivatization with an enantiomerically pure substance could be the way to go, though, but:
unless you have only extremely low amounts of the amine I don´t understand that you have a UV detection problem.
To separate chiral amines, derivatise with Marfey's reagent and run on a C18 column.
Of coures you will need a chiral OPA reagent. It needs to be the thiol. I like to use N-Acetyl-S-Cysteine which then produces sets of diastereomers which can be separated by reversed phase HPLC. Works great!
Amazing! What sort of absolute yields did you get? I junked the conventional OPA method (used just for fluo. detection with the standard thiol), because it was messy.
In total there are 25 users online :: 1 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 24 guests
