Hypersil ENV Column
I've recently received a method that calls for a Hypersil ENV column. I've checked the Thermo website, but I don't see a column by this name. Any ideas on where I could find one or what might be a suitable substitute?
Check the website again, it's the Hypersil Green ENV column range.
Good judgment comes from bad experience, and a lot of that comes from bad judgment.
I had seen this column on the website, but its name is Hypersil Green PAH. Since it didn't say ENV anywhere in its name, I wasn't sure that it was the same column. I guess it is????
Users browsing this forum: Google [Bot], Semrush [Bot] and 2 guests
