Result audit viewer - Empower Report
Hi
any way to get the information in 'result audit viewer' into an Empower report ?
Thinking of including : Summarising sample creation dates and time through to integration and processing and all versions, reasons and final sign off information (errors or manual integration used detailed )
I think these items are all available via various fields in the report editor - no need to plunder audit trail data.
DR
Hi ,
Thanks but where are these fields in the report
ie ,..Result audit viewer and result history or processing method history ?
ie report processing version changes and reasons ?
No tabs in report
Hi ,
I have found sample history as part of audit trail which can be added as report
Nothing else , as in processing method history , sample set history etc
any thoughts/
The processing method and sample set etc history is available to view in reports- when you add the table from the fields list, just double click on it and it brings up a menu where you can include all the revision details or just the current version. If including all versions be aware that the report could be very long if every single update and associated reason is included.
