Ascorbic Acid
Posted: Thu Jul 24, 2008 4:50 pm
Hello every one
I'm working now on captopril development on LC-MS/MS API5000
I use Ascorbic acid as antioxidant in spiked plasma samples by adding 100ul of 0.1M ascorbic acid in 2.00 ml plasma
I do precipetation using ACN for my samples and enalapril as internal standard , the strange thing is like this
ppt of blank alone give good result(clean)
ppt of blank+IS give good result(clean)
ppt of blank+ascorbic acid give good result(clean)
ppt of blank+ascorbic acid+IS(enalapril) give me a huge peak at the drug transition!!!!!!
repeat the trial with all possiblities and gives me same result and so bad linearity
but the linearity of spiked plasma without ascorbic acid give me avery good result
i change IS and get same result
why this happen and
PLEASE can anyone answer ME?!!
why this happen and
