3-(1,2-Oxazolidone)
Could you tell me more about oxazolidone hplc analysis?
Hi ilycip2015,
Does the compound you are interested in have CAS number 497-25-6?
MattM
CAS Number 20073-50-1• 3-Oxazolidineethanol
The analysis can be done similar to this application:
https://helixchrom.com/compounds/ethanolamine/
You will need ELSD, CAD, RI or mass spec to monitor your compound. For ELSD/CAD you can replace ammonium formate buffer with TFA. Retention time is mostly controlled by amount of ions in the mobile phase. You are operating in weak RP and medium strength CE.
Contact me if you have questions.
Vlad Orlovsky
HELIX Chromatography
www.helixchrom.com
www.helixchrom.com
Users browsing this forum: Google [Bot] and 14 guests
