Clear Calibration.
Inject Standards- Normal
Inject Samples x 3- Don't Process or Report (Label U1, U2 and U3)
Inject Samples x 3 - Don't Process or Report (Label U4, U5 and U6)
Inject Samples x 3- Don't Process or Report (Label U7, U8 and U9)
Quantitate U*
When I process the run im getting 2 for the "# of results stored" for each standard and 3 for each sample, shouldn't this just be 1 of each? Im only injecting my standards once, my samples once and using all the stds throughout run to construct the calibration curve, and this curve is used to quantitate all samples. I don't know where the 2 and 3 are coming from any ideas??
