MS/MS
Posted: Thu Aug 07, 2008 6:21 am
by frage
I have a question to be done and if someone knows I respond I am grateful!
I would like to know if peak generated with a MS / MS in ion trap is recognizable in a bookstore and if this is not the case that I probabiltà peak that it is happening only time retention.
all help them make convenient
Posted: Thu Aug 07, 2008 6:09 pm
by MaryCarson
Libraries do exist for MS/MS spectra generated on an ion trap. Your unknown must be in the library for it to be recognized. The ion trap libraries that I know about are not nearly as extensive as the NIST EI library.
Posted: Thu Aug 07, 2008 6:50 pm
by frage
My question of the post comes from an analysis done to determine PCBs in water and the thing that makes me strange is that I find only two congeners on 209 and I'm not sure seems strange.
Thank you for your opinion!
Posted: Thu Aug 14, 2008 12:48 pm
by klimbaka
Is there ESI-MS library, available at all
libraries
Posted: Thu Aug 14, 2008 3:04 pm
by MaryCarson
Halket had produced a library base on (mostly) ESI ion trap data from an LCQ (Deca version, I think). It used to be available from Thermo Finnegan. I confess, I haven't kept up on it, so don't know if it is still available or whether it has been further expanded.
