need help about running Lauryl Betaine on the GC
I am trying to find if there a way to run lauryl betaine on the GC.
I am not sure if this compound is doable by GC either due to its lack of volatility and/or lack of stability.
Please if someone has any information in regards to helping me in this situation, please advise me.
thanks
Amphoterics are tough (internal salts), and typically a mixture....not so easy to assay even in the raw material....
Thank you for your reply .
I am facing a situation about the odor with lauryl betaine.
I ran it on HS-GC/MS and it gave me a little information, but didn't show what is causing the difference in odor. FT-IR and FT-NIR didn't show any difference between good odor and bad odor from the samples that I processed.
thanks
Users browsing this forum: Google [Bot] and 16 guests
