Optimizing applied LC-MS method
I have analyzed an alga sample and an oil sample containing the alga in UV-LC-MS using APCI in positive and negative polarity mode. Scan type is full scan.
I am running a gradient method using water (B) and methanol (D).
Time A% B% C% D% μL/min
0 0.00 0.0 99.0 0.0 1.0 500
1 40.00 0.0 1.0 0.0 99.0 500
2 55.00 0.0 1.0 0.0 99.0 500
3 57.00 0.0 99.0 0.0 1.0 500
4 60.00 0.0 99.0 0.0 1.0 500
5 100 0.0 0.0 0.0 500
The UV-detector is PDA and I am using multi channel detection with wavelengths of 210, 280, 320 nm. Why are my chromatograms and spectra so bad or what parameters do I need to optimize?
file:///var/folders/pb/d3ycr5z174377vzkvd55c1440000gn/T/com.apple.Safari/WebKitDropDestination-HHnHm43I/Skærmbillede%202018-12-24%20kl.%2015.48.08.png
bear in mind that i am not that familiar with LC-MS
Thanks in advance
First and foremost: if you are not familiar with LC-MS, you should get a training from whoever who employs you or let you do this project.
We can not see the picture you posted; see the sticky on how to post chromatograms/spectra.
We don't know what you're trying to analyze, how you are preparing the sample before injection, what type of instrument you are using,.... It's not possible to give any advice.
Users browsing this forum: Bing [Bot] and 5 guests
