Problems with Tune and Thermo MSQ?
Is anyone using Thermo MSQ (not plus)?
I have some problems getting it to work, specifically it seems I can’t turn on nitrogen (toggle gets green, but nothing happens) or change probe temperature from Tune (can put whatever, but readback stays on ambient temp)...
As a followup, I got everything to work and to calibrate with latest MSQ Plus drivers.
The only difference between drivers supporting MSQ and newer which only support MSQ Plus since SP2, was “SurveyorLowMassOption” setting in registry, which needs to be set to 0 for MSQ. All the reference files, calibration etc are still included.
