Analysis of Urea on a Hypersil LC column
I need to analyze urea in an aqueous solution with a Chromegasphere
SI60 15cm X 4.6 mm column. Any suggestion about mobile phase,
flow rate & wavelength.
John R. Carver
Ph. Dallet, L. Labat, E. Kummer and J. P. Dubost
Determination of urea, allantoin and lysine pyroglutamate in cosmetic samples by hydrophilic interaction chromatography
Journal of Chromatography B: Biomedical Sciences and Applications
Volume 742, Issue 2, 9 June 2000, Pages 447-452
http://www.sciencedirect.com/science?_o ... 66c1c9470d
