Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in. http://chromforum.org/
For Agilent 1100. It seems that fans turn on along with hard drive. However, unable to have anything on the monitor. changed monitor and still not able to get it work.
what is the best option forward? the chemistation is without registration.
Re: HP Computer with chemstation unable to boot
Posted: Fri Feb 01, 2019 6:57 pm
by Consumer Products Guy
Find a 10-year-old kid with glasses, he'll fix it.
Was the second monitor taken from a working system??? By the way, if I understand correctly, this is a computer/Windows issue in booting up/seeing monitor, not a Chemstation issue.
Posted: Fri Feb 01, 2019 7:41 pm
by jiangds06
that was mean I don't think the kid can fix it.
and you are right. it is computer/window issue.
If computer is totally fried, could I buy chemstation CD and install it on another computer to run agilent 1100?
Posted: Fri Feb 01, 2019 9:06 pm
by James_Ball
You only need the activation number that is on the box/envelope that came with the Chemstation. That number will work with any disk for Chemstation.
If you are using a DAD or FLD detector and acquire spectra there is a second number for the 3D chemstation you have to enter at setup.
This is a system of CPU overheating. Quite common on older PCs.
Simply need to carefully remove the heat sink, clean and apply new heat sink paste, and replace the heat sink. You should at least get the bios screen at this point.
Posted: Fri Mar 29, 2019 5:04 am
by Henrylozano
Hello, get a new computer, look for XP SP1 operating system, verify what Lan card you have and quiet I can help you with the software.
Posted: Fri Apr 05, 2019 2:53 pm
by JamesLA
I agree with HawkEye_Analytical_1, the problem is most likely caused by a heat sink (it may not be seated correctly or its thermal paste may be old, what happens more often). Check this video tutorial . You can also clean out a computer's case if there's dust in it, to unblock air flow.
