Quantitative Analysis Of Organic Waste by Cappillary GC
Hy Im a student,and I need help in understanding the below procedure.
This is the experimental setup:
(1) Qualitative analysis of organic waste samples
Internal Standard is Ethyl Benzene
Test solvents include: methanol,Acetonitrile,Toluene and Acetone
1) Prepare each of the test solvents and waste samples by the addition of IS.This is achieved by the addition of 1 mls of IS to 1 ml of solvent.
2) Dilute each of the samples and test solvents with dichloromethane in a ratio of 50:50 (v/v)
3) Inject each test solvents and record their retention time's.Also inject the waste samples
4) Qualitatively determine which solvents are present in the waste samples.Use the chromatograms to determine the % composition.
My question here is how to determine the % composition?
(2) Quantitative analysis
Here they asked me to find the Response Factor (F) to find the concentration,of the unknown mixture.
concentration of std/conentration of IS=Fx area of std //area of IS.
My question is
how to find the concentration of std and concentration of IS if there concentrations are not given?
Should i calculate it,if so how?
Sanju Simon
Use area normalization
(individual area / total area) x 100 = % composition
For ISTD calculate RRF (relative respond factor)
(Ci / Ai) x (As / Cs)
Where: Ci = Concentration of individual component
Ai = Area of individual component
As = Area of ISTD
Cs = Concentration of ISTD
Hopefully this information can help you.
M Azmi
Well the concentration is actually given or rather can be calculated in 2 ways.
You know that you add 1ml. So if doing it accurately you can always look up the density for each solvent and calculate the final concentration. Should do for a student project.
Alternatively but a bit tricky if due to evapouration: add the IS first to a vessel (less volatile), put on a scale and zero it, then add 1ml of the solvent of intrest and you get the weight.
How do i do that?
For example take Methanol.It has a density of .79130 g/ml.I used 1 ml.Therefore the Mass i used will be .79130 x 1 =.79310g.
After finding the mass I used,whats the nxt step?
How do I express this in g/ml or in any other concentration terms?
Sanju Simon
Sanju,
If I understand your dilution scheme correctly, you have 0.79g/4ml total volume of sample or ~0.2g/ml. That gives you a response for that concentration of that solvent.
By the way, it should come out pretty close to the area % of that component relative to the other components if you are using an FID. Not exactly because you are not dealing with straight hydrocarbons, but close.
Best regards.
Users browsing this forum: Semrush [Bot] and 12 guests
